Torque Specs
Old Mar 31, 2012 | 09:03 AM
DG_'s Avatar
DG_
Default Torque Specs
I will, hopefully, be installing my new shocks/springs this weekend, but I'm having trouble finding all the correct torque specs. I found quite a few threads on spring install, but none of them mention torque specs when re-installing. I'm surprised that no one has listed those.
Does anyone have that info? Didn't want to buy a Helms man. to find out.
Thanks
Old Mar 31, 2012 | 09:30 AM
157dB's Avatar
157dB
Cut & Paste Expert
Thanks
We dont need no stinking HELMS around here.
Its the internet age.
http://iihs.net/fsm/?dir=1
http://iihs.net/fsm/?dir=53&viewfile=SPECIFICATIONS.pdf
http://iihs.net/fsm/?dir=62&viewfile=SPECIFICATIONS.pdf
You might want to invest in some new one time use hardware before
starting the spring/shock/strut install.
The new upgraded lower strut mounting bolts with the finer threads at least.
And maybe some new upper strut mount bearings to get rid of the stock clunkers.
FRONT:
Brake caliper bracket bolts 98
Dust shield bolts 15
Wheel spindle pinch nut 76
Lower control arm forward bolt 129
Lower control arm rearward nuts 129
Heat shield bolts 89 lb-in
Brake line bracket bolt 15
Strut upper nut 46
Strut-to-spindle bolts 148
Strut-to-body nuts 26
Wheel hub retainer nut 221
Stabilizer bar bracket nuts 52
Stabilizer bar link nuts 85
Anti-lock brake sensor bolt 53 lb-in
Outer tie-rod end nuts 59
Steering gear mounting bolts 85
REAR:
Rear shock absorber upper nut 30
Rear shock absorber lower bolt 85
Lower arm-to-body bolt 129
Brake caliper anchor plate bolts 76
Lower arm-to-axle bolt 129
Panhard rod-to-body mount bolt 129
Panhard rod-to-axle bolt 129
Lateral stiffener bar-to-body mount nut 85
Lateral stiffener bar-to-body bolts 46
Stabilizer bar link bolts 85
Parking brake cable bracket-to-lower arm 20
Upper control arm front bolt 129
Upper control arm rear bolts 85
Upper control arm bushing nut 129
Fuel tank strap bolt 38
Brake hose bracket bolt 15
Old Mar 31, 2012 | 09:35 AM
DG_'s Avatar
DG_
Awesome! Thanks 157dB.
Now I can get started... woot.
Old Mar 31, 2012 | 10:17 AM
DG_'s Avatar
DG_
Also just found this DIY guide. It has a quite detailed step-by-step guide and at the bottom shows all the torque specs.
Here's the link if anyone needs it for future reference:
http://www.stangnet.com/2006/12/22/s...pring-install/
Old Mar 31, 2012 | 12:56 PM
157dB's Avatar
157dB
Cut & Paste Expert
You might like this...
Old Mar 31, 2012 | 10:44 PM
DG_'s Avatar
DG_
Good vid, but ended up starting before I saw your post.
Finished in about 4 hours with all four corners. Solid rear makes it soo easy to change out the shocks/springs, lol.
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
LivingInThePast
Sep 16, 2015 12:20 PM
