Need alignment?
Old May 1, 2012 | 11:17 PM
05MineralGrayV6's Avatar
05MineralGrayV6
Default Need alignment?
Went from 17" to 18" wheels and had the new 18's balanced. Do I need a 4 wheel alignment?
Old May 2, 2012 | 07:16 AM
mayo's Avatar
mayo
Don't ya hate it when you ask a stupid question and nobody gives you a stupid answer...lol.
I'll be your huckleberry...Your good bro, no alignment needed unless something has changed in the handling.
Old May 2, 2012 | 08:28 AM
05MineralGrayV6
Idnt that a daisy? allright lunger lets do this. lol one of my alltime favorites thanks mayo didnt think I would need one but wasnt sure
Old May 5, 2012 | 09:52 AM
157dB's Avatar
157dB
Cut & Paste Expert
There is no adjustment to the front end or rear end that an alignment
can cure. If you are out, you have bent sub-frames that no alignment will fix.
Toe is the only adjustment on the front end you have. Swapping rim
sizes has no effect on alignment IF the rolling diameter of the tires
you installed (hope you didnt reuse the 17" tires on the 18" rims) are
the same as OEM tires.
Now maybe steering stops are in order here so you dont rub the carp
the inside of the tire during full lock to lock turns.
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
