Suspension advice... again..
Old Jul 7, 2012 | 08:27 PM
xx10Gt's Avatar
xx10Gt
Default Suspension advice... again..
Hey everybody i have a 2010 gt convert and finally scraped enough money to pull the trigger on lowering the pony. I was originally going with Steeda sports, and their shocks/struts, lower control arms, and UCA's. I have a couple of questions now though..
-First off, Do i need an adj PH bar? I would think so... but...not sure?
-Also, looking to go with either 19" or 20 rims soon.. so im only looking for a 1.25" rear/ 1" front drop. Should i stick with steeda? There are so many brands out there and ive been reading alot about Koni yellows, opinions?
-What EXACTLY would i need to lower the stang, without sacrificing TOO much ride quality (a little is expected obviously). I have around $1,000 to spend give or take a hundred or two depending on what i need. This is not going to be a tracked car by the way.
Also, would i need LCA's and UCA's? Any input is great along with your set-ups and pictures as well. List all suspension mods.. Just because if im pulling the trigger on a 1k+ i want to make a good investment. Thanks!
Old Jul 7, 2012 | 11:19 PM
Wes_T's Avatar
Wes_T
I lowered my '05 with Steeda Sport springs and Koni Str.t shocks(orange) It was exactly 1" front & back. I did not need a panhard bar.
If your drop is more than 1", I think the conventional wisdom is that the pan/bar is a good idea.
I tracked the car and it was better handeling and a little stiffer on the streets. I eventually put on adjustable LCA's and that's when it got much harsher.
Old Jul 8, 2012 | 01:47 PM
xx10Gt's Avatar
xx10Gt
thanks. and overall would you recommend LCA's or stay away from them?
Old Jul 8, 2012 | 07:59 PM
Wes_T's Avatar
Wes_T
If your not going to track the car, I wouldn't bother. The drop plus shocks struts do a lot for street driving. UCA, LCA'S will really only benefit if you push the car really hard.
Old Jul 8, 2012 | 08:06 PM
xx10Gt's Avatar
xx10Gt
yeah thats true. But heres what i have in mind at the moment....
-UPR adj Panhard Bar
-UPR Upper CA and LCA package
-Steeda sports
-Steeda shocks/struts
Would this be an ideal setup? correct me if im missing something or if you have any input
Old Jul 9, 2012 | 02:57 PM
SteedaBrandon's Avatar
SteedaBrandon
Former Sponsor
I would actually recommend our Ultralite springs for you. The Ultralites are better suited for a daily driver and will provide an approximate drop of 1.25" (F) and 1.5" (R).
With those, we recommend (but is not required) our adjustable panhard bar and heavy-duty upper strut mounts. The upper strut mounts for adjusting camber after lowering.
Old Jul 9, 2012 | 03:26 PM
xx10Gt's Avatar
xx10Gt
If you would like you could throw together a suspension pack for me, its weird because someone else from steeda helped me and said i wouldnt really need the upper strut mounts.
And as far as ultralites vs sports, i wanted to go with sports because it is not as big of a drop. opinion on that?
Old Jul 9, 2012 | 03:29 PM
SteedaBrandon
Former Sponsor
As I said, we recommend the mounts, but they are not required.
My opinion is go with the Ultralites, the drop is almost the same (the "drop" just depends on what you have from stock, it is a general guide and not end-all be-all as your factory ride height varies from car to car).
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
