2013 GT - 1 or 1.5 inch lowering Springs?
Old 07-10-2012, 08:25 AM
Steelios
Steelios's Avatar
Default 2013 GT - 1 or 1.5 inch lowering Springs?
Hey guys,
I'm going to order the FRPP Shocks/Struts and Springs today and I need some quick help. I have a 2013 Mustang GT and I'm debating dropping it either 1" or 1.5". Right now, ground clearance is well over 6 inches with the stock fascia and no chin spoiler. As my daily driver, which drop would you recommend? I WANT to do the 1.5" but, being a new Mustang owner, I'd like some opinions from guys who have dropped their cars.
Thank you all for the help!
Steelios
Steelios is offline
Old 07-10-2012, 08:36 AM
Jarrod@latemodel
Former Sponsor
Jarrod@latemodel's Avatar
Im running the "K" springs on my 2013 right now. We put a set of "P" springs on another 2013 up here and the drop is not enough IMO. I have the Boss chin spoiler as well.
Picture of my car is in my sig.
Jarrod@latemodel is offline
Old 07-10-2012, 09:32 AM
05 Mustang
05 Mustang's Avatar
You should be just fine with the 1.5" drop.
05 Mustang is offline
Old 07-10-2012, 10:45 AM
Steelios
Steelios's Avatar
Ok, thanks guys! I'm going to go ahead with the 1.5" FRPP K Springs.
One other question...do I need anything besides the shocks/struts and springs? I've heard that I need new strut mounts and then somebody else told me that I didn't. They're $110 apiece so I'd like to know whether or not I really need them. Thanks!
Steelios is offline
Old 07-10-2012, 11:37 AM
Jarrod@latemodel
Former Sponsor
If you are using 05-10 style struts, then grab you a set of GT500 Style Strut Mounts. If you are using a 11-13 style strut then you wont need anything else.
This is the exact kit I used
2005-13 Mustang Ford Racing Strut, Shock And Spring Kit
Old 07-10-2012, 11:51 AM
Steelios
Steelios's Avatar
And it looks like that's the exact kit I'll be ordering today! Thanks for the help, Jarrod!
Steelios is offline
Old 07-10-2012, 02:04 PM
Jarrod@latemodel
Former Sponsor
Not a problem.
Old 07-11-2012, 02:08 AM
steel pony
steel pony's Avatar
You will LOVE that setup!!
I've been running this exact setup for over a month now and with the car set on "SPORT" steering, it rides like it's on rails!!
steel pony is offline
Old 07-11-2012, 09:53 AM
05 Mustang
05 Mustang's Avatar
not sure about the newer models, but on the 05-09 mustangs you need an adjustable pan-hard bar when lowering the rear of your car.....it allows you to re-center the rear axle under the car
if you find out that you do need it, here's the bar I highly recommend...the adjustment & jam nuts are located in a very good location that makes life very easy....I've installed others where the adjustments are at the ends of the bars and it makes installation very difficult!
http://bmrsuspension.com/?page=products&productid=172
Old 07-12-2012, 08:16 AM
Jarrod@latemodel
Former Sponsor
This is a good bit of information. I had one on my 06 and just put it on my 13' since I already had one. You wont notice the off center of the axle with a set of stock wheels, but once you put on an aftermarket wheel with wider tires, its easily seen.
Quick Reply: 2013 GT - 1 or 1.5 inch lowering Springs?
