Power steering fluid
Old Aug 20, 2012 | 09:00 PM
tigercrazy718's Avatar
tigercrazy718
Default Power steering fluid
Just wanted to see what you track guys use for your power steering fluid. After my last track day in 90+ degree heat the power steering fluid started boiling (steering got heavy) at the end of some 20 minute sessions. I have a track day thats coming up, and its gonna be a hot one here in Houston, so I just wanted some opinions from you guys. I saw a guy racing a show room stock series v6 mustang last time I was at MSR (which I had no idea existed) and he suggested Redline fluid. Agree? Disagree? Thanks!
Old Aug 21, 2012 | 07:31 AM
Argonaut's Avatar
Argonaut
I use Amsoil. Redline is always mentioned as "the" PS fluid to use. I keep the fluid level at the lowest possible amount. I also frequently change out the fluid...suck it out with a turkey baster and replace with new every few events.
Old Aug 21, 2012 | 08:48 AM
tigercrazy718
Why do you keep it low? And is sucking it out with a turkey baster good enough when changing to the same fluid? I'm assuming when switching from ATF to whatever I'm going to use its probably best to flush it.
Old Aug 21, 2012 | 10:55 AM
TomKat's Avatar
TomKat
i also use the turkey baster method too works well to replace worn down fluid with new
Old Aug 21, 2012 | 06:50 PM
baddog671's Avatar
baddog671
Would Valvoline max-life ATF be an adequate replacement fluid for my 06GT? I'm thinking about flushing the P/S and coolant next oil change.
Old Aug 21, 2012 | 06:53 PM
Argonaut's Avatar
Argonaut
The lower it is the more room for expansion the less likely hood of boil over. Don't go to low, just to the lowest recommended level. You could pull the hoses and do a whole flush of the system but I don't bother. Since I suck out the old and put in new so frequently I don't think there is any need.
I know guys who rubber band a rag around the top of the PS reservoir to soak up any boil over. Me...I never have an issue. I can only assume its because of the steps described - fresh fluid and low level.
Old Aug 22, 2012 | 11:27 AM
tigercrazy718
Ah ok thanks for the info that makes sense. I think this time ill be doing a flush and then after that ill do what you suggested and change the fluid after every hpde or 2
Old Aug 22, 2012 | 03:03 PM
tigercrazy718
o and also how much do I need to buy? i can't find anything except "fill to line in reservoir." no specific amount that I can find
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
stark777
Sep 21, 2015 12:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
