Curious sway bars?
Old Oct 14, 2012 | 09:09 PM
baddog671's Avatar
baddog671
Default Curious sway bars?
I stumbled upon this on the web. Discuss!
Old Oct 14, 2012 | 09:50 PM
defiance's Avatar
defiance
overkill lol
Looks like something from demolition derby really.
Old Oct 15, 2012 | 08:41 AM
Norm Peterson's Avatar
Norm Peterson
They're cobbled-together ways to increase the roll stiffness. Heavier and uglier than finding the right bar for the job.
If whoever needed sta-bars with stiffnesses that are that unusual, I don't understand why didn't they just build just them up from the 3-piece bits that the circle track supply houses sell.
Then again, if those are race cars, it doesn't speak too highly of the rest of the car.
Norm
Old Oct 15, 2012 | 10:10 AM
Old Mustanger's Avatar
Old Mustanger
Agreed, they are just low budget hack jobs. They add a lot of weight without comparable performance. Not to mention the ugly factor....
You would be FAR better off by purchasing a larger/stiffer than stock single sway bar setup.
Old Oct 15, 2012 | 01:09 PM
baddog671's Avatar
baddog671
Ok, I just thought I'd share because I've never seen that before
Old Oct 18, 2012 | 10:36 AM
Sam Strano's Avatar
Sam Strano
Former Sponsor
What follows is a link to my bars for the car. You'll notice all the hardware, and that the front and rear are both 3 way adjustable giving you lots of adjustment, and without the backyard engineering you see above. Your stock bars are 34mm w/4.4mm wall tube front, 20mm solid rear. My bars are 35mm w/6.25mm wall tube in front, 25mm w/4mm wall tubing rear. Both bars get stiffer, but the rear increases more relative to stock bars than the front, which you want because the 2005-2010 cars typically have too little rear roll stiffness and understeer quite badly. I don't want to over bar the rear, that's bad too. And many do using solid 1" bars and front bars that are less stiff being either smaller or having less wall thickness.
http://stranoparts.com/partdetails.p...D=80&ModelID=5
daltron
Apr 28, 2016 08:10 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
