Finished Fays Watt Link Install
Just wanted to give my two cents on the watts install and setup. The install is pretty straight forward. The brackets didn't quite match up with the stock panhard brackets but with some rubber mallet work it worked itself out. Definately like the axle tube clamp setup of the diff connection. Not a huge fan of putting that pressure on the diff. Took about 2 hours with a buddy taking the time to make sure it was all lined up correctly. I have checked the car twice since then for movement on the clamps and there has been none. It isn't exactly the quietest piece on the planet but my car wasn't that way to begin with. It was the last piece of my suspension(well ball joints and bumpsteer next monday) and I will tell you it drives like a frozen rope in the corners. Anyone that would tell you there is no difference in the watts and the panhard can't possibly have driven both. The rear end of the car is absolutely planted. Love it would recommend it to anyone..
