Installed End Links
Old Mar 18, 2013 | 07:40 AM
V8 VOL's Avatar
V8 VOL
Default Installed End Links
I need some schooling.....This weekend I installed UPR Endlinks and they were definitely a nice upgrade.
My question is, other then getting the sway bar to the correct angle due to lowering, is there any other benefit to this adjustment either up or down?
Old Mar 18, 2013 | 07:51 AM
Norm Peterson's Avatar
Norm Peterson
Normally, you'd set the endlink adjustments such that the bar was not under any load with the full weight of the car sitting on its wheels. Ideally this would be with a driver sitting behind the wheel (or the driver's weight simulated with loose weights of some sort).
However, you could use the bar adjustment to even up the corner weights to a limited extent. This is not the preferred approach to cornerweighting your car, but unless you have coilovers it's the only easy method available. You'd need cornerweighting scales for this, otherwise you're just as apt to guess wrong about which way to adjust as right (never mind by how much). Mostly this is a corner-carving mod even though it affect the rear tire loadings some.
Norm
Granatelli Sales
Dec 18, 2015 06:22 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
alymac
Aug 26, 2015 07:46 AM
jjwinel78
Aug 17, 2015 03:34 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
