next suspension mod?
Old May 31, 2013 | 01:51 PM
DTMR's Avatar
DTMR
Originally Posted by UrS4
A couple of questions first.
What wheel (dimensions) and tires (size) are your running?
How lowered are you on the coilovers?
Is your sig complete or are you not listing other suspension mods?
My suggestions and in this order.
MM camber plates with -1.8 degrees camber
18 x 9.5 wheel with summer only tire that is soft and grippy 255/45/18 or 285/40/18 square set up
Watts link
Adjustable sways and adj endlinks
Front LCA
Rear LCA and UCA - adj and one end on the LCA needs to be rod-end like
A arm brace
Subframe connectors
I hate the plates but they are at 1 degree right now and that is my exact wheel and tire set up, as for the front LCA I replaced all the bushings with polyurethane ones and put bumpsteer kit with the steeda ball joints
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
