Suspension installed...Pic!
Old Jun 28, 2013 | 05:21 PM
artdohc's Avatar
artdohc
Default Suspension installed...Pic!
Installed my suspension and wheels and get everything buttoned down.
Eibach Pro-Kit springs
Steeda struts and shocks
J&M Adj PHB
Ford Racing GT500 strut mounts
19"x9.5" SVE Drift wheels all around
One thing, I took my car in for an alignment and I was told my camber is off by 2 degrees. Guy said it will ruin my tires but make the car turn great
He recommended caster camber plates, if I buy them do I have to take the front struts/springs out to install them? Do they basically replace the GT500 strut mounts?
Old Jun 28, 2013 | 06:38 PM
CMcNam's Avatar
CMcNam
Yes, you have to remove the struts and they will replace the GT500 mounts.
Old Jun 28, 2013 | 07:29 PM
VistaBlueFrank68's Avatar
VistaBlueFrank68
Or get the Camber Bolts from AM $24. Are you 2" down? It doesn't look slammed.
Will you have a mechanic ride along with you changing the settings?
Do you have a portable laser alignment machine in the trunk?
If no to all these, just get the Cam Bolts. Get an alignment, done. Save the $300 for a bump steer and larger ball joints. Steeda Bump Steer and X-11 Ball Joints $167 and $157.
I do all three to all my lowered Mustangs.
The black molding makes it hard to see how low it is. Try a side picture with the camera at about 1' off the ground. I liked the result.
Later
Last edited by VistaBlueFrank68; Jun 29, 2013 at 02:08 AM. Reason: 2 deg off? Hmmmm.
Old Jun 29, 2013 | 08:40 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
It looks really good. How did the ride quality change?
Matthew
Old Jun 29, 2013 | 09:53 AM
AJ06GT's Avatar
AJ06GT
Yeah, it is hard to see exactly how it sits with all the black on the white, but that almost works to your advantage even. I think it looks great. Can't wait to do my suspension.
Old Jun 29, 2013 | 12:44 PM
artdohc's Avatar
artdohc
Matthew
It's a little more jarring over harsh bumps, but normal day-to-day driving the added stability of better shocks/struts makes it feel better than stock.
My buddy has a new BMW M3, it felt a bit stiffer than my Mustang when it was stock (which felt very floaty), now both me and my friend have a hard time differentiating the ride quality between the two cars.
Old Jun 29, 2013 | 12:46 PM
artdohc's Avatar
artdohc
It's not, it didn't make the 1.5" in the rear that Eibach said it would drop. 1.25" all around.
Old Jun 29, 2013 | 08:18 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
Looks good. And I wouldn't mess with the camber.
Old Jul 1, 2013 | 01:48 PM
mfergel's Avatar
mfergel
On the S197 forum the guys have said to run the GT500 strut mounts backwards. Basically, you turn them 180 degrees so the arrow points up instead of down.
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
