Camber Gauges
I'd say it depends on what kind of gauge you get. The ones with a graduated bubble-level scale (quarter degree markings?) won't have resolution as good as the kind that have a digital readout (generally these are good to ±0.1°).
I'm currently using a Harbor Freight digital angle finder, also a ±0.1° device. For street driving and any hard driving short of professional racing that should be good enough.
Norm
Norm
Norm
Norm
Do you know the spec for camber on the s197?
They should have better ones. If not, other big hardware sources (Sears, big box hardware emporiums) should.
OE camber is -0.75°, with an acceptable tolerance of 0.75° either side of that. There is a spec for cross-camber, which is the difference between left and right side cambers (I think this spec is 0.7° max difference).
Norm
Norm
Norm
Norm
Do you know of a good resource that offers a walk through of camber adjustment with a angle gauge?
I have the Maximum Motorsports gauge, have not used it yet, but the instructions are posted here:
http://www.maximummotorsports.com/co...ools/MMT-3.pdf
http://www.maximummotorsports.com/st...roducts_id=192
Note to self, might be time to chase it down and tweak it some more.
Norm
I have recently installed the h&r ss springs with eibach prodampers.
I plan on using camber bolts and panhard bar.
All is nearly installed.
I am just going to get an alignment on Monday after my simple camber tune with the angle finder.
Do you guys know the exact specs for alignment so as I may bring these to the shop?
Each of the alignment specs has a preferred setting (which isn't exactly a pass-fail number) and a fairly loose tolerance either side of that. Once you have the ability to adjust camber, you might just find a camber setting that suits you better than nailing Ford's preferred camber smack-dab on the nose.
Toe is -0.1°, ±0.2°, and is adjustable.
Caster is +7.1°, ±0.75° and is not adjustable (unless you step up to caster-camber plates).
Sure wish I could talk you out of using those bolts. Camber plates or Steeda HD strut mounts are better solutions to the same problem.
Norm
Norm
