Which strut/shock combo are you running?
Old 09-03-2013, 01:50 PM
  #21
JayBeStangs94
JayBeStangs94's Avatar
What are you're opinions on the eibach struts and shocks? I haven't heard many reviews on them
JayBeStangs94 is offline
Old 09-03-2013, 01:53 PM
  #22
lawrencecar1
lawrencecar1's Avatar
no complaints here, firm smooth ride
lawrencecar1 is offline
Old 09-04-2013, 08:32 AM
  #23
Scott2
Scott2's Avatar
My suspension mods:
Front Suspension / Bracing:
• BMR Suspensions Tubular K-Member
• BMR Suspensions Tubular A-Arms
• BMR Suspensions A-Arms Support Brace
• Ford Racing Performance Parts Mustang GT Jounce Bumpers
• Ford Boss 302 Strut Tower Brace
• Ford Racing Performance Parts SVT Strut Rubber Insulators
• Maximum Motorsport Caster/Camber Plates
• Maximum Motorsport Strut Mount Hardware Kit, Strut to Spindle
• Shelby Performance Parts Adjustable Front Sway Bar End Links
• Steeda Sport Springs
• Steeda Adjustable Front Sway Bar
• Steeda Light Weight Radiator Support
• Tokico D-Spec Adjustable Struts
Rear Suspension / Bracing:
• BMR Suspensions Xtreme Anti Roll Bar
• Bump Stop Frame Brackets Removed
• Jounce Bumper Relocation Plates
• Steeda Adjustable Panhard Bar
• Steeda Heavy Duty Panhard Bar Brace
• Steeda Adjustable Upper Control Arm
• Steeda Billet Lower Control Arms
• Sway Bar Axle Housing Mounts Trimmed for 15”x10” Rim Clearance
• Tokico D-Spec Adjustable Shocks
• Tokico D-Spec Shock Adjuster Extensions
• UPR Lower Control Arms Relocation Brackets
Parts in inventory to be installed:
• BMR Suspensions Upper Control Arm Mount
• BMR Suspensions Polyurethane Differential Bushing Kit
I like the adjust-ability of the D-Specs, but the ride is pretty rough due to the BMR Xtreme Anti Roll bar.
Scott2 is offline
Old 09-04-2013, 09:08 PM
  #24
I_Call_D.I.B.s
I_Call_D.I.B.s's Avatar
Steeda Ultralite Springs
Koni Yellow adjustable dampers
Maximum Motorsports camber/caster plates
Fays2 Watt's Link
I like this combo a lot. My biggest complaint with the stock 2013 Performance Pack suspension was the floatiness of the chassis mid-corner, followed by how the rear axle felt disconnected from the rest of the chassis. It was kind of unnerving when the car was cornering fine but the chassis felt like it was bobbing around. No more of that!
I_Call_D.I.B.s is offline
Old 09-05-2013, 12:50 PM
  #25
JayBeStangs94
Fays2 Watt's Link
yeah i feel ya on that one. its got partial rigidity but the floatiness is all there. Definitely unnerving. Sounds like a good combo, how comfortable is the ride? Or should i say, how could you describe the adjustability for tight corners and just daily driving?
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
10-07-2015 07:02 PM
heslekrants
09-23-2015 04:02 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
uedlose
09-10-2015 03:30 PM
Quick Reply: Which strut/shock combo are you running?
