J&M Camber Plates vs MM CC plates?
I am in the final stage of collecting all the needed parts to lower my 2005 GT. the last bit is the CC plates/upper strut mounts.
What is the better option to go with, the J&M Camber plates? or the Maximum Motorsports Caster Camber plates? Ive read about both the good and bad with each part, I am just not sure what I exactly need.
I will be running
Ford Racing K Springs and Koni Srt1s (the orange/red struts)
my car is a street car, its not a race car, nor will it be anytime in the future, the nearest race track to me is several hours away. it still has the stock wheels/tire size for now, will be changign that out to 18x9 rims after tax return.
do I need the Max motorsports CC plates? or are they overkill for my needs? ive had MM products on my foxbody and they were awesome quality.
how is J&Ms quality?
I know you get what you pay for but that 150 ish price difference can help pay for some other parts, I plan to order the parts next week
I will be running
I have MM plates on my '95 and they are great. How low are you planning on going? If you are going to stay within 1.5'' drop you could get away with using the GT500 mounts and save yourself a good bit of money.
Matthew
Matthew
Per MM's instructions....
"The purpose of this rubber band is to hold the Stud Plates in position while installing the MM Caster/Camber Plates."
And thats the same reason I didnt get 19's either. Do damn expensive.
Matthew
Do you have your camber plates on backwards? From the picture it looks like your castor adjustment plate is towards the firewall and not the front of the car as I saw in the instructions for the MM plates. I saw that there are two holes in the tower mounting area so I'm guessing that your alignment guy or gal was able to align the car but I installed my castor adjustment plates facing the front of the car. And I do like my MM plates. I just had issue with them getting out of line with the stock upper perch when I torqued the locking nut down one time and had to re-install the ball bearings. But I got it fixed and haven't had any problems with them.
