swapping control arms
Old Dec 7, 2013 | 07:35 PM
Shelty's Avatar
Shelty
Default swapping control arms
ok, so I am replacing my front control arms with GT500 units....
anyone got good advice on how to break those balljoints free of the spindle? ive got the bolt out, but holy crap is it fighting me coming out. anyone got any tips? I went out an got a better pry bar to break the sucker loose, Ive almost got it out finally
Old Dec 9, 2013 | 02:39 PM
JThor's Avatar
JThor
There are two tools. There is a "pickle fork" which is hammered between the ball joint and spindle the taper of the fork separates the two http://www.autozone.com/autozone/acc...ntifier=466511.
There is also a ball joint removal tool which you can rent at a lot of parts stores. http://www.autozone.com/autozone/acc...er=512957_0_0_
Old Dec 9, 2013 | 02:58 PM
Derf00's Avatar
Derf00
Gentleman's Relish
The pickle fork will probably work best and is cheaper, especially since you are not worried about damaging the old ball joints.
I'm getting ready to tackle this myself in few weeks so I've gotten:
* FRPP Control arms (GT500 basically)
* Updated sway bar links since they are also problematic. The updated ones are factory on 2010+. They have a finer thread pitch to hold torque better, red nylon inserts in the nut for locking, and a larger base nut on the link side so you can properly hold the link while torqueing down to 85 ft/lbs.
* New FRPP (GT500) strut mounts since mine also has the loose lumber sound when going over uneven surfaces
* New KYB struts. (and shocks for the rear) I've got around 55K on the car so since I have to tear it all apart, might as well.
The only thing I'm not getting (but I'm really thinking about) are FRPP lowering springs. But only to drop about an 1" . I don't want camber/caster plates or a bump steer kit if I drop more.
Old Dec 10, 2013 | 06:53 PM
Shelty's Avatar
Shelty
I got the driver side one loose, now im just trying to get the new ones in, doesnt seem to want to go in on the drivers side.
Ill have to drab some C clamps and thry to press it in
Bokeo
Oct 10, 2015 08:28 PM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
