Coilovers and panhard, need help with adjustments
Old 04-10-2014, 12:43 PM
JayBeStangs94
JayBeStangs94's Avatar
Default Coilovers and panhard, need help with adjustments
I'll be purchasing my coilovers within a few weeks as well as either a BMR adj panhard or whiteline adj panhard.
I was wondering how I fine tune each shock to get the most comfortable compression ratio, as well as how do I match the front 2 exactly the same ratio and the rear 2 with exactly the same ratio? I have experience with installation but no experience with shock tuning, although I have a general idea.
With the adj panhard, do I match it to the stock panhard's length, or does it need to be matched to the correct length according to how the axle is positioned due to the coils? If so, how do I go about adjusting the panhard to the correct length that it needs to be?
Thank you
Joe
JayBeStangs94 is offline
Old 04-12-2014, 07:35 AM
Black Fire
Black Fire's Avatar
The panhard needs to be adjusted after the coilovers have been done.
As far as shock tuning it's personal preference. Start soft and firm it up to your liking.
Black Fire is offline
Old 04-12-2014, 08:27 AM
Norm Peterson
Norm Peterson's Avatar
Koni's procedure:
Originally Posted by Koni Technical Note
KONI ADJUSTMENT TUNING GUIDE
Suggested Adjustment Procedures For Road Racing Use
Adjusting The COMPRESSION (Bump) Damping Control
(Very Important to do this FIRST!)
Bump damping controls the unsprung weight of the vehicle (wheels, axles, etc.). It controls the upward movement of the suspension as when hitting a bump in the track. It should not be used to control the downward movement of the vehicle when it encounters dips. Also, it should not be used to control roll or bottoming.
Depending on the vehicle, the ideal bump setting can occur at any point within the adjustment range. This setting will be reached when "side-hop" or "walking" in a bumpy turn is minimal and the ride is not uncomfortably harsh. At any point other than this ideal setting, the "side-hopping" condition will be more pronounced and the ride may be too harsh.
STEP 1: Set all four dampers on minimum bump and minimum rebound settings.
STEP 2: Drive one or two laps to get the feel of the car. Note: When driving the car during the bump adjustment phase, disregard body lean or roll and concentrate solely on how the car feels over bumps. Also, try to notice if the car "walks" or "side-hops" on a rough turn.
STEP 3: Increase bump adjustment clockwise 3 clicks on all four dampers. Drive the car one or two laps. Repeat Step 3 until a point is reached where the car starts to feel hard over bumpy surfaces.
STEP 4: Back off the bump adjustment two clicks. The bump control is now set. Note: The back off point will probably be reached sooner on one end of the vehicle than the other. If this occurs, keep increasing the bump on the soft end until it, too, feels hard. Then back it off 2 clicks. The bump control is now set.
Adjusting the REBOUND Damping Control
Once you have found what you feel to be the best bump setting on all four wheels, you are now ready to proceed with adjusting the rebound. The rebound damping controls the transitional roll (lean) as when entering a turn. It does *not* limit the total amount of roll; it *does* limit how *fast* this total roll angle is achieved. How much the vehicle actually leans is determined by other things such as spring rate, sway bars, roll center, ride heights, etc.
It should be noted that too much rebound on either end of the vehicle will cause an initial loss of lateral acceleration (cornering grip) a that end which will cause the vehicle to oversteer or understeer excessively when entering a turn. Too much rebound control in relation to spring rate will cause a condition known as "jacking down." This is a condition where, after hitting a bump and compressing the spring, the damper does not allow the spring to return to a neutral position before the next bump is encountered. This repeats with each subsequent bump until the car is actually lowered onto the bump stops. Contact with the bump stops causes a drastic increase in roll stiffness. If this condition occurs on the front, the car will understeer; if it occurs on the rear, the car will oversteer.
STEP 1: With rebound set on full soft and the bump control set from your earlier testing, drive the car one of two laps, paying particular attention to how the car rolls when entering a turn.
STEP 2: Increase rebound damping three sweeps (or 3/4 turn) on all four dampers and drive the car one or two laps. Repeat Step 2 until the car enters the turns smoothly (no drastic attitude changes) and without leaning excessively. An increase in the rebound stiffness beyond this point is unnecessary and may result in a loss of cornering power. Note: As with the bump settings, this point will probably be reached at one end of the car before the other.
However, individual drivers may find it desirable to have a car that assumes an oversteering or understeering attitude when entering a turn. This can be easily "dialed-in" using slightly excessive rebound settings at either end.
Norm
Norm Peterson is offline
cr620
10-03-2022 10:18 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Quick Reply: Coilovers and panhard, need help with adjustments
