Considering going lower...
Old 09-04-2014, 07:25 PM
Keep it real
Keep it real's Avatar
Default Considering going lower...
So I've had the SR springs on for about 4 months and I'm satisfied however I'd like to go a little lower to eliminate wheel gap. After some looking around I wound up looking at the Sportline kit. Installing isn't a problem since I've done it once before I'm just wondering if it's worth dumping these and going with eibach kit. I am also on stock shocks/struts, don't know if that would be a factor or not. And I'm sure that they'll be less gap since I've upgraded to the 20x10 AMR's. Opinions, pros/cons, whatever let me know your opinions!
Keep it real is offline
Old 09-08-2014, 11:39 AM
MustangGTMark
MustangGTMark's Avatar
Hows the current config working for you? looking to so something similar!
MustangGTMark is offline
Old 09-08-2014, 12:49 PM
Andy13186
Andy13186's Avatar
Another option is going with larger diameter tires whenever you get new tires to fill in the gap
Andy13186 is offline
Old 09-09-2014, 05:51 AM
Scott2
Scott2's Avatar
Consider going with an Air Lift Performance suspension and eliminate the gap once and for all!
File Type: jpg
File Type: jpg
Scott2 is offline
Old 09-09-2014, 08:20 AM
darksky1984
darksky1984's Avatar
This is probably your best option. These cars have huge wheel wells and even lowered with the stock 19inch wheels it still leaves a nice gap from the fender to the wheel. Lowering your car more might help some but you will be grinding your undercarriage on every speed bump, curb, or driveway you go on. So lowering your car might help improve the gap but your drive-ability will be miserable around town. They didn't make these cars like BMW's which have barely any gap between the wheel and fender. Good luck.
darksky1984 is offline
Old 09-09-2014, 12:52 PM
Genxer
Genxer's Avatar
There's always adjustable coilovers. Then you can fine tune the ride height to your liking.
I wouldn't buy bigger diameter tires.
Genxer is offline
Old 09-09-2014, 01:16 PM
JayBeStangs94
JayBeStangs94's Avatar
If youre not looking to spend much I'd go with the H&R super sport springs. They're awesome. My buddy is running them on his stang, check it out
http://scontent-b.cdninstagram.com/h...76029878_n.jpg
JayBeStangs94 is offline
Old 09-09-2014, 09:45 PM
Keep it real
I like the current setup but I want it to go just a little lower. Might would sell you the springs I have now if I go this path and if you'd want them... A pic from before Name:  imagejpg4_zpsdef5953d.jpg
Size:  113.7 KB and after to give a comparison Name:  imagejpg2_zpsa30e4128.jpg
Haven't considered that but I haven't had these tires for but 3 months and they will only be summer tires and wheels
Unless you can hook a brother up for free to $300 I'm good. Would I take bags? In a heartbeat.
^^^ again much more money than what I'm wanting to spend for the time being. And agreed on the tires. I'm more for the square setup and don't think I can get taller tires up front, not much more anyway.
There are not hardly any places around here where I foresee a problem, however I could be wrong. And I'm not having any issues now with this setup.
I'll take fer springs pls! I'm about 99.9999999% sure that just sold me. Thank you!
Old 09-10-2014, 02:25 PM
Andy13186
Andy13186's Avatar
it looks like that car would be nearly totaled from a speedbump or a gutter/driveway. back tire rub issues at all? what size?
OP what size tires do you have?
Old 09-10-2014, 09:35 PM
Keep it real
I'm running 275/35/20's all the way around. Might step up to 285's next time I have to get tires. The ones in that pic look like stock wheels but I'm not sure
Quick Reply: Considering going lower...
