New Wheels and tires, car pulls right, steering wheels shakes when held straight
Old Jan 13, 2016 | 06:48 AM
JethreneSlack458's Avatar
JethreneSlack458
Default New Wheels and tires, car pulls right, steering wheels shakes when held straight
So I got new wheels and tires for my 05 v6 (Jethrene). I took it to ford to get an alignment done because I knew something wasn't right. They had to replace the outer tie rods, and then they aligned the car. Well it still pulls right when I let go of the wheel and the steering wheel shakes when I hold it straight. I don't know what it could be since I just got an alignment done. Wheel balance issue? Some other suspension part? Thank you for all your help.
Old Jan 13, 2016 | 02:54 PM
SCCAGT's Avatar
SCCAGT
Balance issue or bad tire. A slipped belt in a tire will definitely cause a vibration. And depending on how its slit, will make it pull. Easiest way to check if its a tire is to swap the fronts side to side. If it pulls the other way, ding ding ding...bad tire. Usually the side it pulls to is bad. Visually, you cannot tell its bad unless the belt has slipped enough to cause a visible lump in the tread.
Just because they are new, does not mean they are good.
Old Jan 13, 2016 | 07:16 PM
JethreneSlack458
Thank you, I will see about getting the tires balanced again and see if it makes a difference. Would you recommend a plain jane balance or a road force balance?
AMAlexLazarus
AmericanMuscle.com
28
Mar 1, 2016 12:39 PM
Gun Jam
Jan 16, 2016 08:19 PM
01S2Roush
Jan 12, 2016 12:51 AM
4.6kid
Wheels & Tires
Jan 7, 2016 02:10 AM
rds1952
Dec 22, 2015 04:51 PM
