S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
control arm question again
Old Jul 14, 2008 | 08:55 PM
funtimesalways's Avatar
funtimesalways
Default control arm question again
before anyone says, yes i tried search, dosent work. before i even drop that HO whipple in the SGT, i plan to replace the control arms. 1. is it even worth replaceing the upper 2. do i need adjustable lower control arm or not. i notice there are non and adjustable. which one would i require for the SGT that is already lowered. thanks everyone
Old Jul 15, 2008 | 09:58 PM
majustin1's Avatar
majustin1
Default RE: control arm question again
Yes it is worth it to do the suspension mods. I would get the adj upper control arm and the non adj lower control arms. I have BMR and i hate to say it, but i would try a different brand like steeda. Plus, it seems steedas UCA is better for autocross which is just up the SGTs alley. While you are there, go ahead and get an adjustable panhard rod, and the brace if you want. There should be good instructions on how to install them as well. It might pay off to look into the weld in (or bolt in) lca relocation brackets since you are already lowered. I would again go steeda bc they have 4 slots for adjustability while others have only 3.
Happy hunting.
My recomendation
Steeda non adjustable LCA with poly bushings in both ends
Steeda adjustable UCA with poly bushing
Steeda adjustable panhard rod
and Maybe
Steeda panhard rod brace (its like 100 bucks)
Steeda LCA relocation brackets (there a good idea dependign on how far you wanna go)
Old Jul 15, 2008 | 10:49 PM
funtimesalways
thanks for your help on this. its a project that is going to take its time, but i started homework early to avoid costly mistakes. thanks agin
Old Jul 25, 2008 | 09:32 AM
BMRFabricationSales's Avatar
BMRFabricationSales
Former Sponsor
You do not need an adjustable lower unless you have an aftrmarket rear end. Sometines they do not get the lca brackets in the right spot therefore then you would need the adjustable arm to correct your wheelbase.
Old Jul 26, 2008 | 02:13 AM
funtimesalways
thanks gents
GimpyHSHS
Sep 18, 2015 12:27 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
Dragonus18
Sep 9, 2015 01:21 AM
cbird1177711
Sep 2, 2015 04:12 PM
