S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
Bad cats problem...
Old Jun 24, 2010 | 12:02 PM
Lifter583's Avatar
Lifter583
Originally Posted by .boB
Your Redline oil could be the problem. CI oils have a lower amount of ZDDP, because that is what clogs the cats. That's a big deal with flat tappet cams in older Windsor motors. Not a problem with the mod motors.
Some Redline oils conform to CI standards, and some are race only for use in cars without cats.
I am running Schhaffer 5/50w oil...good thing to look for...but I do think the fouled plugs caused fuel burn in the cats...I am honestly happy it happened...glad to get rid of those POS...
Old Jun 25, 2010 | 01:35 PM
Mullens's Avatar
Mullens
Originally Posted by Lifter583
I have the new high flow cats with the H-pipe installed...can really see the difference in the tach moving through the redline...it was quite a bit slower before...now I have to be careful not to bounce it off the limiter at 6800 rpm...
If I were you I'd lower that limiter. Unless you have built internals your rods will eventually go bye bye.
Old Jun 25, 2010 | 01:53 PM
Lifter583's Avatar
Lifter583
These hand built 5.4's wont have a problem with hitting that limiter now and them...I dont make a habit of it though...Brenspeed sets that point in their tune so the engine will run through the redline at full potential...according to my dyno results...best shift point is at 6200-6300 rpm...
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
Sep 24, 2015 09:18 PM
