Sound while turning at low speed?
Im getting what I can best describe as a sweak or something when I turn left at low speeds.
Not sure about right.
I dunno if something is rubbing somehow or if its just because the car only has 4k mi. on it, or if there is some sort of suspension issue.
Are there any TSB's on an issue like this?
Could it be one of these:
08-5-10
8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
Or maybe it is this one?
Axel Whine TSB 09-20-4
Does the GT500 have a 8.8 Limited Slip like the GT's?
Does my year model fit into these? (cant tell)
Just in case... I have a 08 GT500
08-5-10
A GT has 300 hp and limited slip so yes, the GT 500 would need a limited slip as well. It's standard and probably is the cause of your noise. At 4000 miles the limited slip might need to be broken in a bit more. It's not really an issue.
There are 2 TSBs related to this topic......one has to do with upgraded strut mounts and the other has to do with the replacement of you r front LCAs......seems there's new bushing and a larger (1mm) ball joint. Had both done in my '08.....helped quite a bit.
Good luck!!!
Good luck!!!
