Shaker 1000 help
Greetings!
I need to know how to disconnect the plugs on the back of a Shaker 1000 sub system.
There are two plugs that are mounted to a bracket with a retainer clip for each plug. I have disconnected the retainer clips but I am unsure how to disconnect the plugs. Each plug has the same style of plug.
Any help any one can give me would be greatly appreciated.
You disconnect them by pushing down on the hold-tab on the 2 connectors coming out of the shaker 1000 sub box rear that goes into the amps mounted bracket connections.
See THIS: http://iihs.net/fsm/?dir=385&viewfil...0Enclosure.pdf
Plug moved up to the top of the unit in my picture. This is obviously fully removed, including the shaker 1000's rear sub's amps sitting off to the left in this picture. Sittin' on my couch...Poor lighting, but the first link pdf should be more than enough anyhow.
JoshyGT
Sep 19, 2017 08:52 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
