Is this normal ... and what causes it...
Check clutch ... Mine is being replaced soon after 40,000 miles since tsb and over 600lbs of torque .. Mine finally is dead .. Well I could still drive just can't engage the big power.. Sux too.. Lotsa vettes, crapmaros and challys passing me since I can't play... Ordered my mccleod rxt
Still driveable ... But just cant go wot without slippage at top boost levels
Could be.. I dunno ... Most I have spoken with to still have stock clutch and over 54,000 on the clock is pretty darn good ... Think I had about 9,000 on original clutch before tsb..
If not then that's your problem.
If so I'd say you beefed it up a lot from stock and it's JUST the clutch giving you probs now.
So... Did u get the 2010 GT500 parts or not? What year was the TSB done? And what kind of HP and TRQ you running?
Wait ... The TSB was for the 07-09's flywheel causing the problem. Did you not get the 2010 flywheel and clutch put in?
