S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
Fail Safe Mode
Old Dec 8, 2014 | 11:32 AM
todrick's Avatar
todrick
Default Fail Safe Mode
Just curious. Was driving today and decided to have some fun. I noticed that when I mashed the throttle all the way down really quick, even in 6th that the rpms would almost redline and then it said fail safe mode. Was it just a result of pushing the throttle down too quickly? Was kinda the top half of the pedal that I pushed. Still have stock airbox and throttle body on it for now. Looking t do a tune and jlt intake soon though. Searched and found where people were throwing codes, but that was with aftermarket pieces. Do I need to disconnect battery for a bit as well? Any input appreciated.
Old Dec 8, 2014 | 07:55 PM
ticopowell's Avatar
ticopowell
Sounds like your clutch is slipping, when I floor it in 6th gear the revs barely move. I would recommend fixing anything and everything before modding the car, that makes sure that the mods don't break anything and cars are easier to diagnose without mods.
Disconnecting the battery for a few minutes and then hitting the brake pedals will make sure the system is discharged, that will reset the volatile memory of the PCM and it will have to relearn all of it's learnable parameters. You might, but aren't likely to, notice a performance difference until the computer has relearned everything.
Old Dec 8, 2014 | 08:49 PM
tbar's Avatar
tbar
Have you checked it for codes?
Old Dec 14, 2014 | 06:35 AM
todrick's Avatar
todrick
No codes, but took to dealership. Was indeed the clutch. They hooked me up too. $100 deductible for the certified pre owned warranty is all I had to pay, even though the clutch was a normal wear item. 3 days in a free rental as well.
Old Dec 22, 2014 | 05:18 PM
keriortega's Avatar
keriortega
I had the same problem with my 05 GT. It got to where it happened every day. I forget what code it was throwing. Long story short, it was the alternator causing that to happen. Changed out the alternator and no problems for the last 4 months :-)
Old Dec 22, 2014 | 05:30 PM
keriortega's Avatar
keriortega
Actually, it was the throttle body--Once that was changed, no more fail safe mode. (I got 2 incidents mixed up. Sorry!)
jwog666
Dec 27, 2021 08:09 PM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
whatsup62
Sep 3, 2015 01:38 PM
