Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
installed steeda LCA's and UCA
Old 03-30-2008, 02:47 PM
Saleen#468
Saleen#468's Avatar
Default installed steeda LCA's and UCA
By far one of my best mods yet. I figured that it would get rid of the wheel hop (which it did) but i thought that would be about it. The rear suspension feels much more solid in the corners and i think that it did increase grip off the start. Ill be heading to the track when the weather gets better to see if my 60ft got better. By far the best $300 ive spent on the car. Next will be a rear sway bar and adjustable panhard bar.
By the way the UCA install was a B!@tch. would have been easier if i removed the panhard bar and brace, and lowered the fuel tank.
Saleen#468 is offline
Old 03-30-2008, 03:27 PM
slammer1
slammer1's Avatar
Default RE: installed steeda LCA's and UCA
468: Did you use the access door under the rear seat for UCA?
slammer1 is offline
ChiDiddy
ChiDiddy's Avatar
hey im not sure which is the steedo LCA but i just installed the Spone adj LCA. Does yours make little sqeeky noises now on bumps etc? And yes the wheel hop is def. gone when you install these.
ChiDiddy is offline
Old 03-30-2008, 06:36 PM
Saleen05797
Saleen05797's Avatar
You guys get wheel hop? What exactly is wheel hop because either I don't get it or I'm thinking of the wrong thing (I drive with tracking control off if that makes a difference)
Saleen05797 is offline
Old 03-30-2008, 08:48 PM
PolkThug
PolkThug's Avatar
ORIGINAL: Saleen05797
Wheel hop is when you do a burnout and the wheels starting hopping, this also can make the rest of the car shudder. In one of Ford's early ads for the new Stang you can see the car in the video wheel hopping.
PolkThug is offline
Old 03-30-2008, 08:55 PM
Saleen#468
Saleen#468's Avatar
Saleen05797, i only got wheel hop if i hit the gas and spun the tires while i was already rolling. it did it really bad in second gear. you will know if it happens because the rear end chatters loud and you get a bad vibration.
Slammer, no i didnt use the access door under the seat. would that have made it easier to torque the nuts. the torque and getting the bracket off far enouph to get the bolt out was th only hard part.
Chididdy, no i have no noise at all. i used plenty of lube when i did the install. i bought extra just incase the parts didnt come with enough.
Old 03-30-2008, 09:02 PM
PolkThug
PolkThug's Avatar
The Ford wheel hop commercial + wheel hop slomo at the end.
PolkThug is offline
Old 03-30-2008, 09:05 PM
ChiDiddy
ChiDiddy's Avatar
oh ok i guess i just buy a lube gun and lube that sucker all up
ChiDiddy is offline
Old 03-30-2008, 09:12 PM
08Steeda
08Steeda's Avatar
Default RE: installed Steeda LCA's and UCA
I had an 05 Stock GT Convertible and now have my 08 Steeda which has all Steeda suspension and traction control systems. The difference is amazing! I can tell you the HOOK UP is amazing. Especially in warmer weather. I felt like I actually had a hard time spinning the tires. The Seat Pant G-Meter was awesome! To grin from ear to ear!
Good to hear another Steeda Mod made the owner happy!
Nice looking Stang, too!
08Steeda is offline
Old 03-30-2008, 10:19 PM
Saleen05797
Is there a reason why I never get wheel hop? My tires just spin...
Quick Reply: installed steeda LCA's and UCA
