Huge tire headache...gimme a hand plzzz
#21
RE: Huge tire headache...gimme a hand plzzz
I ordered these today with 245/35/r20 for the fronts http://www.goodyeartires.com/goodyea...p;sidewall=VSB
#23
ORIGINAL: 06Saleen3V
Sorry to hijack, but PM wasn't working and am trying to save our youngin' from making a big mistake
Father Jazzer
#26
ORIGINAL: nrcollectibles
The tires used as an option for the 2007 Extremes were Michelins in size 285/30/20 all around. You can get them through Tire Rack.
I thought the front rims were only 9's?
#28
ORIGINAL: Jazzer The Cat
I agree with uncle. I have not seen 285's approved for 9"x18" rim. This may differ with 9"x20" rims, but don't know why it would.
Jazzer
Jazzer
#29
Mickey, sent you a PM, but says your mailbox is full. I STRONGLY recommend you forgo the GS-D3's and go PS2's. Same sizes available and a FAR superior tire. Especially when you start going higher HP, you will WANT all the traction you can get.
Father Jazzer
Father Jazzer
#30
For those of you with the stock Dunlop Sportmaxx tires ('05-08), what sort of mileage are you guys/gals getting before having to replace them?
I just hit a pothole at 45 mph (arrrgh -- never drive your Saleen at night on L.A. surface streets...). My wheel and suspension seem fine. But the sidewall on my (stock) Dunlop Sportmaxx is blown out. It has a huge lump the size of a golfball, which I guess means the belts in the sidewall are torn/damaged. Soooo, I need a new tire. I was going to just get the same Dunlop to replace it. But then I figured that I may as well swap out both fronts to get some Michelin PS2s, since I'm getting 305/35-20 PS2s for the rear wheels once they wear out.
However, I wasn't sure WHEN my rears might wear out. They look good right now, with 18k miles. So I figured I'd ask you folks how long your Dunlops have lasted.
Btw, I was going to start a new thread, but when I did a search for Dunlop Sportmaxx tires and this thread came up. It seemed to have enough helpful information to warrant reviving.
