Old 10-22-2015, 07:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Power outlet in center console not working
Old 03-30-2011, 11:35 PM
Hotwheelracer
Hotwheelracer's Avatar
Default Power outlet in center console not working
Just got the car a month ago, tried to plug my charger in the power oulet in the center console, no power. Works fine from the one in the dash. Is this a fuse issue? Would there be a fuse dedicated to just this outlet because everything else works?
Hotwheelracer is offline
Old 03-31-2011, 07:40 AM
pat6674u
pat6674u's Avatar
I can tell you the fuse for the dash plug and center comp plug are separate, as I had the opposite happen with my car. Pull the fuse for the dash and replace. Otherwise it could be unplugged or just bad.
pat6674u is offline
Old 03-31-2011, 09:03 AM
obxdude018
obxdude018's Avatar
It's most likely the fuse, another possibility if someone removed the center console before they could of forgotten to hook up the connection for the 12v outlet
obxdude018 is offline
Old 03-31-2011, 10:07 AM
Hotwheelracer
Thanks for the advice gentlemen, I will fiddle with it this weekend.
Old 03-31-2011, 12:03 PM
Nuke
Nuke's Avatar
http://iihs.net/fsm/?dir=40&viewfile...ar Lighter.pdf
The 2nd sheet shows both fuses at the BEC.
Nuke is offline
Old 04-06-2011, 09:28 PM
Twstones
Twstones's Avatar
In case you haven't check, the center consul is fuse #64, and the dash power point is fuse #61 Both are in the power distribution box, under the hood, and they're both 20 amp.
Twstones is offline
Old 04-11-2011, 10:07 PM
DansZJ
DansZJ's Avatar
Thanks guys. I had the same issue with the center console. I had checked the connections this weekend and was going to replace the socket. It was just a blown fuse. Save me money & time.
DansZJ is offline
Old 04-11-2011, 10:17 PM
05windviel
05windviel's Avatar
also be sure to keep the plug on it because sometimes coins can get inside of the socket and cause the fuse to blow thats why they have the nifty cover
05windviel is offline
Old 04-12-2011, 03:03 PM
Hotwheelracer
Ding, Ding, Ding, we have a winner!. Checked my outlet, darm Abraham Lincoln stuck in there. Pulled him out with some tape and a pencil. And now the outlet works. Man did I feel dumb for this being such an obvious thing to check.
Thanks for pointing this out, I like using this outlet much better to charge my phone as opposed to the on in the dash.
Old 04-12-2011, 11:04 PM
05windviel
05windviel's Avatar
no prob its really easy for one to get in there and its hard to tell if there is because its in the console
Quick Reply: Power outlet in center console not working
