*NEW* JDM 302E Block, FRPP Stage 2 Ported Heads, Hot Rod Cams & ALL parts 2 complete
Category: Engine - Complete Motors
Price: $9950
Part fits: S197
Location (State/Prov): GA
Item Condition: Brand New
Up for sale Today. I have a complete New engine build for sale. I want to try to sell it complete. If no interest? then I MAY... sell seperately. This was set up NOT to be a drag race engine, but to be very "streetable" and fun to drive. I was originally planning to just use the Saleen Supercharger, which will only put out 600 rwhp or so... and add a second power adder (NO2) with 110 for track day.
Current configuration:
- JDM 302E Short Block with Forged rotating assembly. This is the lower compression version that can be used for Supercharger or Turbo applications. $4200
http://www.teamjdm.com/jdm-302e-2005...t-block-motor/. *$5995 new at JDM
- Ford Racing Stage 2 CNC ported Heads (M*6049*N3VPA & M*6050*N3VPA) Set up with all new lash adjusters and followers.
http://www.teamjdm.com/4-6l-5-4l-cnc...ead-assembled/
I have had several requests for price breakdown for this.
$4200 - JDM 302e
$850 - FRPP Ported Head (LH) Note add $360 to the price of the heads ($180 each) if sold separately for lash adjusters and followers (Already installed)
$850 - FRPP Ported Head (RH)
$730 - Ford Racing Hot Rod Cams (M*6550*3V)
$360 - ARP Cylinder Head Fasteners
$150 - FRPP 8 Bolt Flywheel
$330 - Triangle Speed Shop TSS 3V Billet oil pump gear
$65 - GT500 oil pump
$315 - FRPP Chrome Valve Covers
$560 - 3V Timing Cover with Mirror Finish - Debured & Polished Timing Cover ($260 new timing cover + $300 polish)
$150 - MMR Billett Rear Engine Seal Support (if you dont like MMR? then I also have a new Ford OEM Part to replace).
$470 - Canton 7 qt Aluminum Oil Pan 13-784A
$1670 - All new parts required to assemble a complete Engine: lash adjusters ($150), followers ($210) NOTE: Subtract out if heads sold seperately, Timing chain, guides, VCT, Cam position sensors, all other sensors (For 2008 wiring harness), seals, all nuts and bolts... EVERYTHING you will need to complete.
FOR SALE $ 10,700.00
I have properly assembled the engine following Ford manuals and Todds advice (Thank you Sir) tmcolegr. Using new...calibrated tools and all required "Rotunda" Tools. The Engine is currently ready to have Valvoline Racing Oil pumped through it and install the oil pickup tube and pan, valve covers and timing cover. The rest is straight forward... sensors (2008), rear engine seal and drop in your car!
Additional parts available to purchase separately to complete... Inovators west 10%OD, Meziere Electric water pump, Thump Racing Saleen tensioner, on and on. I will post up additional threads for these.
Retail is at $13731.19 EDIT NOTE: I forgot to add in the Canton oil Pan...
Price reduction: For Sale Today $9950 Plus Shipping and Crating fee's.
or I could remove the Hot Rod cams and Sell for $ 9220 Plus Shipping and Crating fee's.
The only other option to lower the price for this??? would be to remove the following parts; HR Cams $730, Timing Cover $560, FRPP Valve Covers $315, Canton oil Pan $470, and the flexplate/Flywheel (used for Automatic) $150. That would be for sale at $7725.00 + shipping and crating fees
I will accept payment by discrete PayPal or you pay the fee (3 now 4%??), Cashiers check from Major Bank or Credit Union.
Located in Atlanta, GA. Local pickup prefered...
Thanks for looking!
Michael
Photbucket Links:
Last edited by Ledgend Shaker; 03-24-2015 at 09:25 AM. Reason: Added options to reduce price...
Alright... I have had several people come very close to buying this now and just could not come up with the $$.
The only other option I can come up with to lower the price for this??? would be to remove the following parts; HR Cams $730, Timing Cover $560, FRPP Valve Covers $315, Canton oil Pan $470, and the flexplate/Flywheel (used for Automatic) $150. That would lower the price to $7725.00 + shipping and crating fees.
I can always add the parts onto my Wife's 08 GT or sell separately.
Let's see if this option works!
Still for sale!
I have someone who wants the block. Does anyone want the heads along with the new lash adjusters, followers, cams, cam sensors, VCT and timing components?
xbmx89
Texas Regional Chapter
11-10-2015 10:43 PM
KEM Motorworks
08-14-2015 10:13 PM
