2017 GT intermittent cold start issue
Intermittent difficulty starting cold (occurs maybe 1 of 4 times). Drove the car off the lot 3 weeks ago. Have already had it serviced twice and the problem still persists. One of the injectors was replaced, then the starter was replaced. Multimeter to battery reads >12.6. Problem only seems to happen when it's been sitting for a while,
Take a listen: https://www.youtube.com/watch?v=Gfgt...ature=youtu.be
-Crank sensor?
-Fuel line issue?
-Fly wheel issue?
-PCM?
Should I be calling Ford directly at this point?
-Crank sensor?
-Fuel line issue?
-Fly wheel issue?
-PCM?
Issue was fixed by replacing PCM. Able to duplicate issue pretty consistently by driving car for 10 minutes, and restarting after an hour or two. Unsuccessful attempts previous to this: replace starter, replace fuel injector 6, fuel compression, purge valve solenoid, spark plugs, battery, any air/fuel mix issue. Car starts perfectly every time now.
