Headlight issue
Old 01-08-2018, 08:03 PM
tadpole1969
tadpole1969's Avatar
Default Headlight issue
ok got a headlight issue i have no head lights, only tail lights ,brake lights, parking lights, and turn signals , my flash to pass works, i changed the head light switch and the multifunction switch, checked all fuses all were good , also the high beam notification light doesnt work either and fog lights do not go out when i switch to highbeams lights like they did,only thing is fuse 4 and 10 have no power with lights on and key turned to on postion, kinda stumped ! anyone ever run into this issue and solve it?
tadpole1969 is offline
Old 01-08-2018, 08:33 PM
Z28KLR
Z28KLR's Avatar
Checked relays?
Z28KLR is offline
Old 01-08-2018, 09:02 PM
tadpole1969
theres no relays for headlights on 2001 mustang gt only a 30 amp maxi fuse in engine compartment fuses box, as far as i know there isnt anyhow
Old 01-09-2018, 05:25 PM
tadpole1969
its got to be a wireing issue i think , cause high beam indicator doesnt even come on the cluster no power im guessing
Old 01-09-2018, 07:35 PM
Urambo Tauro
Urambo Tauro's Avatar
The diagrams for my '95 are different, so I'll avoid posting them, but I managed to find this through Google. This is supposedly the diagram for a 2000, which is a lot closer to your 2001 than what I have.
Urambo Tauro is offline
Old 01-09-2018, 09:43 PM
tadpole1969
ok thx Urambo Tauro ! i will let u know how it goes soon i hope!
Old 01-12-2018, 07:04 PM
WJL
WJL's Avatar
DOES YOUR CAR HAVE DAYTIME RUNNING LIGHTS?
WJL is offline
Old 01-12-2018, 08:13 PM
tadpole1969
not that i know of but it may ,i know fuse 30 in fuse box has fuse in it for it ,gonna check that tomorrow
Old 01-12-2018, 10:39 PM
Z28KLR
Z28KLR's Avatar
Unless it was originally intended for sale in Canada then there will be no drl.
Z28KLR is offline
Old 01-16-2018, 06:52 PM
WJL
WJL's Avatar
Sorry i have been socked in with snow, attached is a diagram that should help. I crossed out the DRL circuit and added the wire to the high bean indicator light. I also marked the high beam circuit. Also the tail lights have their own harness
Sorry for the poor art work, i don't like windows 10
File Type: pdf
WJL is offline
Quick Reply: Headlight issue
