2014 mustang mustang drag/squealing idle through rpms
Old 03-19-2018, 09:37 AM
Nates14gt
Nates14gt's Avatar
Default 2014 mustang mustang drag/squealing idle through rpms
My 2014 mustang gt is making a noise at idle through the rpm range, it sounds metallic like and it sounds like it’s from the trans. Its like a squeal/ squeak. The car has a rst clutch/ fly wheel and a mgw. It’s not coming from up top or below on the engine. I’ve never heard a noise like this from a car. I’ll post a video of the noise.
car has 46 thousand miles.
Nates14gt is offline
Old 03-20-2018, 06:40 AM
Buck Sergeant
Buck Sergeant's Avatar
Nate, sounds like a throwout bearing going bad. Does it make this sound when the motor is running and the clutch pedal is to the floor?
Buck Sergeant is offline
Old 03-20-2018, 07:09 AM
Nates14gt
Nates14gt's Avatar
Thanks for the reply! Yeah it makes it with the clutch pushed to the floor.
Old 03-21-2018, 07:03 AM
Buck Sergeant
Nate, if the clutch in your Mustang is whining when the clutch pedal is pressed in, your problem could be a faulty throwout bearing or "clutch release" bearing. These bearings tend to go out over time due to driving conditions, and can eventually leave your Mustang immobile if not tended to. Make sure your clutch system is operating properly by replacing your worn out or malfunctioning throwout bearing. I would change everything, clutch pressure plate and pilot bearing upon doing this job.
Old 03-21-2018, 08:20 AM
Nates14gt
Nates14gt's Avatar
Sounds good, Buck. I’ll be sure to get the heavy duty throw out bearing. I appreciate the advice.
voltekka
12-27-2017 01:51 AM
Xeremeh
08-26-2012 04:13 PM
AlabamaCobra
05-28-2007 04:16 PM
racer02GTstang
02-14-2006 12:51 PM
maddogg20
03-31-2004 08:45 PM
Quick Reply: 2014 mustang mustang drag/squealing idle through rpms
