Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Help: Vortech Supercharger and Aftercooler
Old 04-06-2018, 08:24 PM
Jriess122
Jriess122's Avatar
Default Help: Vortech Supercharger and Aftercooler
Has anyone installed the Vortech supercharger and after cooler? I would love some pictures if you have them. I am trying to figure out how to situate everything (pump, wiring, etc.). I had the supercharger already installed but I am putting the after cooler in now and I could use some brain blocker help. Directions say to install the pump fuse holder and wiring to the # 18 fuse, but that's a blinker relay or something weird? Thanks in advance.
Jriess122 is offline
Old 05-16-2018, 09:42 PM
Jriess122
Jriess122's Avatar
I must be the only person who has ever done this. I guess I will post some pics. Its not finished yet. This is a preliminary fit.
2003 Mach 1 Mustang. Vortech supercharger and Aftercooler in the process of being installed.
Different angle.
Old 06-07-2018, 10:48 AM
Jriess122
Jriess122's Avatar
Default More pics
Pump installed.
Cooling radiator installed.
Upgraded wiring. Needed more than came with.
I added a waterproof quick connect. Not necessary, but easy install.
Ground wire connectors updated.
Water pump connected.
Boguht a Mishmoto Radiator. IT WILL NOT FIT. Too big.
Shown for placement of clamp. If you do not install like this you will have to move.
I put these light weight clamps on here but had to cut a corner off for the elbow to install. AT least they fit.
Radiator installed, clamps installed. Getting closer.
Here are a few more pics. I am doing as I get time. I hope I can come back later and add detailed notes etc.
Old 06-08-2018, 12:42 AM
08'MustangDude
08'MustangDude's Avatar
IF the pump has a temperature trigger wire, then POWER for the pump can hook up to
any ignition source in the fuse/relay center.
People are using an FMIC because the after-cooler is too much bulk, and plumbing work.
08'MustangDude is offline
Old 08-14-2018, 01:09 PM
sweetbeats
sweetbeats's Avatar
Don't know if this thread is dead or not, or if I can be any help, but I have an '01 GT with the Vertech charger and Maxflow Power Cooler system installed. I didn't do the install, but in my estimation with what work I've done on the car since being involved with it (4 years or so) it appears the system was installed according to Vortech's instructions.
Let me know if I can help.
sweetbeats is offline
Old 03-19-2019, 02:19 PM
Jriess122
Jriess122's Avatar
The pump does not have a temp trigger. It's just positive/negative. Sorry it took me so long to say anything, but moving and life just won't let me get much done. I do have more pics coming, but its been slow going. Thanks for taking the time to reply and I will try to be more proactive.
Old 03-19-2019, 02:25 PM
Jriess122
Jriess122's Avatar
Super nice. I appreciate the pic. I am trying to keep the thread alive but have little time to work on it and am trying to get more posted as I continue. It is a lot closer. and I should have more pictures soon. I have had to do more modifications because of poor installs on lights and other items I had other people do and they really botched it up. Sometimes it does not pay to pay someone else to do the job. Thank you for your reply.
Old 11-07-2019, 04:59 PM
Jriess122
Jriess122's Avatar
Do you have a picture of the pump installed? Be nice to see how they hooked it up if possible.
Old 11-07-2019, 05:01 PM
Jriess122
Jriess122's Avatar
Also I assume they put your battery in trunk? Do you have any pics of that? I am having issues with the battery install since mine had been routed back there, but I also had 2 other batteries back there that I removed. Sorry for being so needy.
StangKid018
03-16-2012 06:44 PM
rfcsoulja
V6 General Discussion
08-30-2011 10:35 AM
one eyed willy
08-16-2011 09:11 PM
mrsinister2424
04-27-2009 10:35 PM
Boostaddict
S197 Shelby Section
11-05-2007 04:09 AM
Quick Reply: Help: Vortech Supercharger and Aftercooler
