SPEEDO PROBLEMS PLZ HELP
Old 05-24-2018, 05:22 PM
Justin Schuster
Justin Schuster's Avatar
Default SPEEDO PROBLEMS PLZ HELP
Do i have a 98 mustang gt close to stock with a couple bolt ons and i ran into this issue where my speedo and odom isnt working anymore ive tried changing the vss and its got the gear so i made sure the old one was good, i even sprayed out the connection with air and it was fine, No luck so i toon apart my cluster and replaced the gears, stil no luck and checked the fuses on the panel inside the car and they were fine somebody plz help its drivin me crazy
Justin Schuster is offline
Old 05-24-2018, 05:23 PM
Justin Schuster
Default Add on
Also after changing the sensor it was still throwing a code for p0500
Old 05-25-2018, 01:06 PM
Z28KLR
Z28KLR's Avatar
www.obd-codes.com/p0500
Here's some additional info on that dtc. Starting point for me would be to inspect wiring, especially since you've already gone to the trouble of replacing the sensor, speedo and cluster gears.
Z28KLR is offline
bikeboy587
07-23-2007 06:02 PM
bikeboy587
07-23-2007 03:22 PM
bikeboy587
07-22-2007 03:28 PM
getnmineinmay
Chop Shop
03-29-2005 12:08 AM
Quick Reply: SPEEDO PROBLEMS PLZ HELP
