07 6v mustang p108
That code is too short for anyone to verify it, so we'll take your word on that.
The MAF is in the filter box housing tube, dunno how you are missing that.
Right where the hose clamps on to the air box, the sensor is right in front
of the clamp. It's a combination MAF and IAT sensor.
might check to see if that air intake tube doesn't have any rips or holes... You can also clean the MAF with MAF cleaner, but they do get less effective as time goes by...I put a new on my old 93 Tbird which was having horrible pinging... new one put on and the pinging went away forever.
Why can't you even type the code right? There is no P108, you're missing a digit!
You were already TOLD where the MAF sensor is.
Right there...
unfortunately 08, you were wrong here. Mr. Medina has a V6 such as yourself and even tho he did leave out the first 0 in the code, the P0108 is indeed a MAP code for the V6. its integrated around the intake manifold with the EGR. I myself didn't realize that either, didn't know that Ford was still using EGR valves in 07 and probably till 09.the pic you posted is indeed the V8 MAF sensor and location.
