SVT Forums
Look at these dirty, dirty pistons. And oh, my cakey head.
Old 09-19-2018, 12:11 AM
Stokestack
Stokestack's Avatar
Default Look at these dirty, dirty pistons. And oh, my cakey head.
Hi all.
Finally got the driver's side head off my '96, to fix a failed helicoil repair for the ol' blown-out-plug defect. I need to ream out the hole and put a Time-Sert in there.
Meanwhile, though, would anyone like to weigh in on the condition of this engine? Obviously the surfaces are caked with carbon and gunk, but I'm intrigued by the differing condition of the cylinders. The front two have flaky deposits in the center of the pistons, whereas the back two are more evenly coated.
The #6 cylinder (second from the left here) is the one that stopped firing.
What's a safe way to go about cleaning these surfaces?
Thanks for any insights.
Stokestack is offline
Old 09-19-2018, 04:35 AM
08'MustangDude
08'MustangDude's Avatar
Can spray them down with carb cleaner, kerosene, or even parts cleaner.
Dab a rag in kerosene and wipe everything down, then spray with parts cleaner.
If stubborn, let the stuff soak in Marvel Mystery Oil, then wipe and spray.
08'MustangDude is offline
Old 09-19-2018, 04:46 AM
Stokestack
Stokestack's Avatar
Thanks. Wasn’t sure what was safe to put into the cylinders.
Old 09-19-2018, 06:39 AM
ZEN357
ZEN357's Avatar
Yeah, it will be safe. I sold my Mustang because I bought a Challenger and didn't want to deal with the whole spark plug blow out issue.
ZEN357 is offline
Old 09-19-2018, 01:35 PM
Looks like the valve stem seals are/were leaking in the oily cylinders.
Old 09-19-2018, 02:55 PM
08'MustangDude
Also looks like the head gasket was about to fail on those first two cylinders
as well. Unless that ran down after taking it all apart...
Still, yeah, you can clean that all of with an assortment of things, as long as you
do not scratch or score the cylinder walls. Hell, you can pressure wash it with
scalding hot water. We have a pressure washer with a propane heater on it we
use.
Old 09-19-2018, 04:38 PM
Stokestack
Stokestack's Avatar
Thanks guys. I did notice those breaches of the gasket under the front cylinders. No opinions on the different conditions of those cylinders vs. the other two? I wonder if both the color and gasket leak are the result of high temps. The engine got very hot (but didn't technically overheat) a couple years ago.
The #6 cylinder has stuff in it that needs to be cleaned out (most likely powdered glass from a broken borescope lens). Fortunately, it's the one at the top.
Given the way this looks and that I now want to take the passenger-side head off, I'm revisiting the idea of putting the 2003 tumble-port heads on. But so far I haven't seen a definitive guide on what I need to do to adapt them to a '96.
MonguseAz
12-09-2016 07:15 AM
9550
09-04-2013 10:06 PM
Gregski
Mustang II Section
04-24-2010 02:10 AM
my94pony
06-18-2009 10:45 AM
r.barn
08-05-2006 02:46 AM
Quick Reply: Look at these dirty, dirty pistons. And oh, my cakey head.
