93 mustang WONT START!!
Old 12-09-2018, 03:09 PM
Shane179y
Shane179y's Avatar
Default 93 mustang WONT START!!
Hello im having problems with 1993 mustang gt, i bought this car as a project and was expecting there to be problems. when the key is turned the absolutely nothing happens, no lights, sounds, no nothing. we have replaced almost everything starter, battery, ignition switch, solenoid, and the key switch. we have jumped the car from the solenoid and it will turn over and idle for 3 seconds before what sounds like the car cutting its power. when the car is jumped from the solenoid all the lights on the dash come on and everything else comes on.
we have checked all the grounds and they seem in perfect condition.
Please if anyone has any knowledge on this please help i have worked for many hours on this car and am stumped at this point
Please help!!!
Shane179y is offline
Old 12-09-2018, 10:03 PM
imp
imp's Avatar
Please help!!!
When it turns over jumping directly to the starter, does the engine spin at what seems a normal rate? Starts and dies suggests a fuel problem separate from the starting problem. Have you looked into rot in the battery cables? I've had them turn the copper wires completely to green powder, inside the insulation, where it cannot be seen.
imp is offline
Old 12-09-2018, 10:08 PM
Urambo Tauro
Urambo Tauro's Avatar
Sounds like it's time to break out a multimeter, or a test lamp at the very least. Find out how far voltage is getting, if it's even able to make a complete circuit at all.
Urambo Tauro is offline
Old 12-10-2018, 05:56 AM
Shane179y
Shane179y's Avatar
yes it seems to spin at a normal rate with no problem, although we havent checked the battery cables yet but they seem in good condition
thanks for the help
Old 12-10-2018, 05:58 AM
Shane179y
Shane179y's Avatar
there is no voltage at the kay or fuse box or anywhere before the solenoid. any other good spots to check that could cause this?
Old 12-10-2018, 06:20 AM
Urambo Tauro
I'd start right at the battery cables and go from there. Grounds, fuses...
Old 12-10-2018, 06:42 AM
Shane179y
Shane179y's Avatar
ok will do thanks for the help
Old 12-10-2018, 08:44 AM
GT Nate
GT Nate's Avatar
sure your distributor timing is way off?
GT Nate is offline
Old 12-10-2018, 09:06 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check the ignition switch mounted on top of the column, common issue, they'd separate causing contact issues
mjr46 is offline
Old 12-10-2018, 12:12 PM
Shane179y
Shane179y's Avatar
we changed that but dont have the small electrical clip rod thing could that cause the car to have no power?
Quick Reply: 93 mustang WONT START!!
