Low speed shimmy.
That can be so many things, but start basic, bad tire; a belt broke in the tire.
Balanced or not, I have had it happen... Put your spare tire on, one location at a
time, see if it stops. If you went all the way around the car with the spare, and
it did not stop the shimmy, then it's not a tire. Doubt two tires would have blown
belts. Potholes are the #1 case of tire damage.. OR, bending rims...
Then you move on to suspension; bushings...
Then check the axle bearings, one side may be going.
Check for axle play...
