Wheel/Tire Fitment Cal Special
Old 03-24-2019, 12:16 AM
46CaliSpecial07
46CaliSpecial07's Avatar
Smile Wheel/Tire Fitment Cal Special
Hello mustang forum, I am knew to this site, and was looking for an answer to my question. I've got a 2007 Cali Special. I am currently running the stock wheels and tires. They are 18x8.5" wheels I believe, with 235/50r18s on them. I am thinking about upgrading to a 19x9.5" wheel, but am not sure what size tire I want. I like the wide look, but I also do not like a stretched tire. I would prefer to NOT have staggered fitment because then I would not be able to rotate them. Would there be any rubbing issues? What can I fit without rubbing issues? I am totally open to any suggestions. I have looked into the Nitto 555G2s, but I do not know what size. I live where it rains a lot, so I would need something to wick water, but also want performance. Should I upgrade? If so, what?
This is what I have:
46CaliSpecial07 is offline
Old 03-24-2019, 07:55 AM
Norm Peterson
Norm Peterson's Avatar
My recommendation is for Michelin Pilot Super Sports in either 255/40-19 or 265/40-19. The 255 tire is a little smaller than OE, the 265 a little larger - I'm talking only a couple tenths of an inch here. I really think you'd be hard-pressed to see the difference unless the two options were side by side. You will want the offset to be about +45, which will let you run them in any position on the car with no need for spacers up front.
And the reason I'm recommending the MPSS is because they're good enough in the rain to be one of about two "go-to" tire choices for track driving in the rain. Meaning that you're getting extra margin at lower speeds over most any other tire in the wet. Even in 285/35, at 110+ mph at the very end, once I got past the spray being thrown up by the Corvette. My Mustang's "street set" is 265/40-18 on 18 x 9.5, differing from what you're looking for only in 18" vs 19" wheel diameter. Tire Rack currently lists the 255/40-19 on special closeout and priced accordingly. Run that size 1 psi higher than what your car's door sticker calls for.
Norm
Norm Peterson is offline
sammyd16
12-12-2013 01:24 PM
RocinRon
Wheels & Tires
01-19-2013 05:04 PM
Funster_2011V6
Wheels & Tires
01-01-2011 11:03 AM
natedog
07-16-2009 10:39 PM
bl1nk
06-04-2006 08:33 PM
Quick Reply: Wheel/Tire Fitment Cal Special
