2006 Mustang GT engine rattle
Hello, I have 2006 Mustang GT that has a rattle when i rev up the engine. I talked to a Ford dealership and they said it was the timing chain, but when i opened it up the timing chain, the guide rails, everything was fine. I replaced it anyways while i was in there, but the rattle is still there. I'm hoping someone can identify the rattle or tell me of some diagnostic steps i can use to figure it out. Here is a link to an audio recording of my engine.
https://www.dropbox.com/s/0ejxn90z6m...10503.mp4?dl=0
Thank you for any help you can offer.
What all did you replace while you were in there?
A common failure point for 05-06 4.6L 3v engines are the timing tensioners. They use a gasket and are made of plastics instead of a machine fit cast iron/aluminum so while the guides might be ok, the tensioner doesn't hold tension and allows the chain to bounce around even if the guides are ok.
luqqzr
3.7L V6 Technical Discussions
10-01-2019 08:02 PM
ProjectLacey
03-25-2015 05:27 PM
