hotrodder 858
Old 04-30-2024, 11:38 AM
hotrodder 858
hotrodder 858's Avatar
Default hotrodder 858
19865 mustang stock 289 has dura spark 2 dist. runs great with no vacuum advance, hook up vacuum advance it dies just past idle. Tried different dist and modlues.
hotrodder 858 is offline
Old 05-06-2024, 02:56 PM
Mostang66
Mostang66's Avatar
I've been waiting to see if someone would respond to your problem. I have a Shelby dual point (converted to Pertronix), which is mechanical advance only. There should be others who have more practical experience with vacuum advance on a 289 to respond. Regardless, you are obviously using ported vacuum (timed), which should be O.K. What do you have the ignition timing set at with the vacuum line disconnected? It sounds like there should be a little less advance when you initially set the ignition timing so that when the throttle plate begins to open and vacuum is introduced, it doesn't slam the ignition too far in the advanced direction.
Mostang66 is offline
Tinyp
05-11-2022 12:23 AM
Clein1996
05-20-2015 03:32 PM
Jasonwayne222
06-23-2012 08:53 AM
Jetblue65
06-18-2011 07:01 AM
Sharp66
01-03-2010 06:58 AM
Quick Reply: hotrodder 858
