Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
will this SD setup work?
Old Feb 28, 2008 | 11:31 AM
wheelliftnpony's Avatar
wheelliftnpony
Default will this SD setup work?
96 explorer Gt-40 Heads and intake. 24lb injectors, 75MM T/B, intake spacer, U/D plulleys, electric fan, by pass smog and ac, 100shot of nitrous, CAI, 255Intake fuel pump, and a nitrous SD cam with control arms and a fresh T-5 tranny.. if this will all work togather what do you guys think number wise, Track times and hp?
Old Feb 28, 2008 | 11:52 AM
Alero99's Avatar
Alero99
Default RE: will this SD setup work?
plain H/C/I i know puts SD at its limit b/c the 19lb injecters, that 100 shot may not work, PM dime bag he knows his ****
Old Feb 28, 2008 | 04:35 PM
nitrousd85's Avatar
nitrousd85
negative on the injectors go 19 and you'll be fine
my guess at or above 300
Old Feb 28, 2008 | 05:45 PM
pimpinstang1's Avatar
pimpinstang1
which one is smog??? is it the one on the bottom left??
Old Feb 28, 2008 | 07:34 PM
wheelliftnpony
ya thats smog, bottum left.. I wasnt sure on the injectors, i figured they would be boarder line.. I just want 300hp..
Old Feb 28, 2008 | 08:25 PM
stangbanger87's Avatar
stangbanger87
yeah stick with the 19's tha 100 shot is ok and the h/c/i will work great .
Old Feb 28, 2008 | 09:21 PM
wheelliftnpony
ok sweet. and as far as suspension for a 300hp car at the track.. What would i have to do to hook up? We dont need adjustable control arms and frame ties do we?... Right now the car wheel hops really bad.. It has the vertical shock on it to.. What can i do to fix wheel hop?
Old Feb 29, 2008 | 01:40 PM
stangbanger87
frame tie it , boxed upper and lower (you could weld in some flat steal on the stock ones to box em in, or buy aftermarket)run four cylinder springs in the front and flick the front sway bar (will make the car shift the weight more to the back)renforce the rear torque box (complete the welds on the factory set up )get a set of drag radial's or 10.5 slicks will help in the hook .
this should get ya pretty stable .
how were you guys going to do burn outs and launch off the light ?
can i sugest foot brake the burnout and run four wheel line lock for the launch.a racer i know does this and it works very well for his 10.5 car ,the four wheel line lock alows the car to get all the twist and bends out so it will launch like a rocket when the light drops .
they call it chasis preload .
Old Feb 29, 2008 | 04:50 PM
dimebag's Avatar
dimebag
please explain this line lock consept to me... i dont see how itll work with a 5 speed car
anyway
you have a good plan, go with comps nitrous SD cam, keep the 19s(we could make 21s work, but lets not get into that), that intake yes. the 100 shot, go wet and yes, id be weary of the tb upgrade, cai is fine, udp is fine, that will work together great
depending on gears( 3.73s) expect high 11/low 12 on the spray if u can drive the **** out of it
Old Feb 29, 2008 | 05:40 PM
wheelliftnpony
ya, well my bro will be driven hes gettn good.. I power shift the hell out of my 88gt..i think were gonna go with 4.10's
