Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
will this SD setup work?
Old Feb 29, 2008 | 05:41 PM
wheelliftnpony's Avatar
wheelliftnpony
Default RE: will this SD setup work?
would u go with a plate system under the upper intake? or just spry it into the cai
Old Feb 29, 2008 | 06:40 PM
nitrousd85's Avatar
nitrousd85
if got any extra $ put the battery in the trunk it'l help a bit transfering weight
oh yeah one more if you know any good horse jockeys let them race your car 100 pounds = a tenth those little ***** weigh like a 100 even, thats how you can pick up a little more
Old Feb 29, 2008 | 07:40 PM
stangbanger87's Avatar
stangbanger87
i didn't realize the car was a 5 spd at the time dimebag , i was thinking it was auto that is my bad there .aint the port size on the intake 65mm for the tb ? that is what matches mine .and like i said i thought they were running an automatic in it , that four wheel line lock method won't work on a stick .
Old Feb 29, 2008 | 08:59 PM
wheelliftnpony
ya i figured about the line locks.. but ya me and my bro weigh both 110 lol.. and i forgot about the battery in the trunk good one.. Thanks man ill post updates and pics of the car when the snow stops outside.. thanks guys
Old Mar 1, 2008 | 10:18 AM
dimebag's Avatar
dimebag
yes but a 65 mm tb can confuse the sd system. ill explain it later or sumthin
Old Mar 2, 2008 | 02:08 PM
nitrousd85's Avatar
nitrousd85
hey dime bag i got no funny issues when i installed my aftermarket tbody and spacer if i rember right its a 75mm
dont hold me to that it might be smaller
what issues should this action cause in a sd car curious now
Old Mar 2, 2008 | 04:08 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
not that it WILL, but it can... the comp uses the tps to say how much air should be going in also... if the tb size is bigger, it might not notice the extra air...
Old Mar 2, 2008 | 07:24 PM
stangbanger87
that is what i heard to but my q is what if the signal is mdified to the ecu , i have a conyrol that modifies my signal from the tps to my ecu .any one have any ideas?
hey nitrousd85 your tb looked to be atleast around 70or so when you showed it to me .
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
M3hunter
Sep 5, 2015 03:42 PM
cbird1177711
Sep 3, 2015 08:43 PM
