Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
vibration?
Old Mar 3, 2008 | 01:41 AM
enoughsaid's Avatar
enoughsaid
Default vibration?
I have a vibration at higher rpms in every gearon my 87 notch, i thought it was the u joints but i cant get any play out of them. Do you think it is an out of balance drive shaft or is there something else that usually vibrates on these 5.0's, because my 91 gt does it too. Any help is appreciated.
Old Mar 3, 2008 | 06:05 AM
stangbanger87's Avatar
stangbanger87
Default RE: vibration?
mine does th samething in high rpms but in normal operateing it is fine not quite sure on what it could be but we can find out
Old Mar 4, 2008 | 09:55 AM
enoughsaid's Avatar
I know someone has some insight in this.
Old Mar 4, 2008 | 10:09 AM
Hawk's Avatar
Hawk
My first thought and the most probable would be your tires. Possibly from being out of balance or from cuppage. For example, one of my vehicles had bad vibration right around 60mph. If I slowed down or speeded up it went away. The issue was the tires having some slight cuppage. When they wore out treadwise, I replaced them and now there isnt any vibration at all.
Old Mar 4, 2008 | 10:25 AM
enoughsaid's Avatar
I thought that might be the case too, but it happens at an rpm range not a speed range. It also doesn't do it unlesss it is in gear. I will be changing tires and rims real quick here anyways.
Old Mar 4, 2008 | 04:42 PM
stangbanger87
i know that my rear tires are trash but are balanced too they are just a little thin , my brother in law calls them home made slicks lol.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
