Cam,Cams,Cammed and more cams
03-08-2008, 09:23 PM
when choosing a cam what determines how lopey it will be at idle. what is the lopies cam you can put in a sd car>
03-08-2008, 09:37 PM
D.R. THE PATHETIC DORK
RE: Cam,Cams,Cammed and more cams
duration /valve overlap determines how agressive the lope will be
03-08-2008, 09:39 PM
so the higher the duration and valve over lap the more aggressive?
03-08-2008, 09:42 PM
usually works that way!!
03-08-2008, 10:39 PM
yea but with speed density we need alot of separation to get them to work well... sd cars w. cams arent lopey, end of story
03-09-2008, 11:55 AM
well said dimebag
03-09-2008, 06:17 PM
so no lopey?????? that sucks. hows on performance?
03-09-2008, 08:04 PM
probably squeeze with the right combo 270 to 280 rwhp out of a sd car......cause at the range you'll be pushin the 19 lb injectors close to their max duty cycle and for more hp after that you'll most likely need a sd tunner to alter tune for larger injectors
03-10-2008, 07:21 PM
so if i want to drop 24lb injectors on my sd setupid have to get a custom tune?
03-10-2008, 09:32 PM
you will have to lose the stock ecu and go with an aftermarket like megasquirt or xfi.
