Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
SD+Automatic= what cam
Old Mar 23, 2008 | 10:30 PM
88ttop5.0's Avatar
88ttop5.0
Default SD+Automatic= what cam
Iam in the process of having my short block being assembled and id like to choose a cam finally, i know i have limitations with the speed density in the car and having a automatic but i was wondering if anyone on here has a cam that they have used and noticed a nice gain without tuning and of course a nice lopey sound... if its not worth it ill just have a longer down time for the car and save up for a maf conversion. Im most likely going to have a 2500 rpm stall converter in the trans also if this helps any.
Old Mar 24, 2008 | 11:57 AM
1mustang's Avatar
1mustang
Default RE: SD+Automatic= what cam
i had an 86 and the biggest cam you can run is a ford e303.498 lift do to the flat top pistons
Old Mar 24, 2008 | 05:36 PM
midnight1's Avatar
midnight1
i just put the crower 15511 in my 88 gt speed density. 486 lift and it runs great with speed density
Old Mar 24, 2008 | 07:25 PM
stangbanger87's Avatar
stangbanger87
the xe264hr works well with sd and it is a .512 lift . far as a lopey sound won't happen as the lobe seperation angle has to be at 114 degrees seperation.
1mustang how did you run an e303 in an 86 sd when the lobe seperation is 112 on the letter cams?
Old Mar 24, 2008 | 11:27 PM
dimebag's Avatar
dimebag
theres no way you ran an E cam w. SD
that comp might work, but for those pistons, it may have ptv issues. either way ptv needs to be checked w. any cam in any motor
as far as what will work w. those pistons im not sure, but i can point you to some ppl that would know
**** then again, w. the limitations your working with, custom sounds like a very good idea
then AGAIN, flycutting pistons isnt that expensive, and **** youd have a few more cams to work with
midnight... other mods? and how do you like that cam
Old Mar 24, 2008 | 11:29 PM
dimebag's Avatar
dimebag
and an e cam is 110 LSA i THINK
Old Mar 25, 2008 | 12:50 PM
stangbanger87
it very well could be 110 but either way a letter cam can not be ran in sd app.
Old Mar 25, 2008 | 01:06 PM
88ttop5.0's Avatar
88ttop5.0
thanks for the suggestions, right when i thought there was a solution to wanting a nice cam with performance and lope speed density had to buzzkill it...
Old Mar 25, 2008 | 06:15 PM
stangbanger87
yeah man that is the breaks with stock sd.
Old Mar 25, 2008 | 07:18 PM
ih8chevy's Avatar
ih8chevy
there are certain cams you can put in ur car without worrying so much about the comp. my suggestion is that you think about how big a stall converter and rear gears you want, then pick a cam. 5.0tech has a chart of cams that works with sd so go on that site and look it up. I cant get to it now otherwise I would show you.
hope this helps
