Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
stalling in gear
Old Apr 25, 2008 | 09:53 PM
thethirdmurph's Avatar
thethirdmurph
Default stalling in gear
so I got my windsor motor running and took it for a spin.. seems to be idling a bit high (900-1000 rpm's) but when I come to a stop it stalls.. if I put the car in park or neutral it idles fine (just a bit high). anybody know off hand what could cause this?
Old Apr 26, 2008 | 04:56 PM
thethirdmurph
Default RE: stalling in gear
anybody?
Old May 4, 2008 | 09:27 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
What is your setup??? I take it that you have an auto, which one (c4 or AOD)? Carb or SD?
I just cured a very similar problem on my 83 carbed c4. My fuel filter was getting clogged from all the stuff that has collected in the tank over the years. As soon as I put it in gear it would drop the idle down to like 250-300rpms, have a hard time on take off, and didn't want to idle high enough to stay running when it was cold while in park.
Old May 5, 2008 | 09:52 AM
stangbanger87's Avatar
stangbanger87
you are saying it stalls when you hit the brake on the car ? sounds like it is pulling to much vacume from somewhere .
Bokeo
Oct 10, 2015 08:28 PM
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
