Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Roller/nonroller dizzy question...not gears
Old May 23, 2008 | 07:16 PM
will's Avatar
will
Default Roller/nonroller dizzy question...not gears
I am in the middle of converting my 95 5.0 to carb. My problem is the dist I pulled out has a longer shaft from the gear down than the one i'm putting in. AM I GOING TO PUMP OIL OR NOT!!! I see the hyd roller block oil pump driveshafts are diff than the non roller blocks any ideas?
Old Jun 5, 2008 | 10:42 AM
HACKGT350's Avatar
HACKGT350
Default RE: Roller/nonroller dizzy question...not gears
i've never heard of this. if it doesnt pump oil then get a new drive shaft for the oil pump. best way to tell if your getting pressure or not before you hook up fuel and park crank the engine over and see if you are getting an oil pressure reading on your gauge
Old Jun 7, 2008 | 01:54 AM
93_5.0_gt's Avatar
93_5.0_gt
they will both work. only diff is the distance the dizzy is down on the shaft. im running a points dizzy and have no issues at all
Old Jun 7, 2008 | 09:43 AM
68CSTANG's Avatar
68CSTANG
To the OP, did you ever get it figured out?
Old Jun 7, 2008 | 10:58 AM
will's Avatar
will
Yup I sure did, I stuffed modeling clay in the shaft installed it then removed it. There's more than enough shaft to turn the pump. Been runnin for a week now and no prob. Thank you all
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
