Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
HIGH RPM PROBLEM!!!
Old Jul 13, 2008 | 02:12 PM
klrs87's Avatar
klrs87
Default HIGH RPM PROBLEM!!!
I have an 87 GT I recently purchased and haven't driven much at all. Here is my problem: the car runs extremly well until you have driven for a while and it's good and warm. The temp gauge reads around 180 and stays there. That's when the RPM's climb to around 2000 and stays there. I'm still learning guys, I need help! I was told to remove and clean both the EGR valve and the IAC. I CAN'T FIND THEM! I feel like an idiot![sm=bangbang.gif] Can someone please help educate me so I can clean these? Thank You very much!!!
Old Aug 3, 2008 | 06:58 PM
onefast86lx's Avatar
onefast86lx
Default RE: HIGH RPM PROBLEM!!!
The EGR is on the backside of the throttlebody spacer and the IAC is on the front
Old Sep 2, 2008 | 04:45 AM
mstngsule68's Avatar
mstngsule68
best thing to do, go to your autoparts store and pick up a haynes, DONT get a chilton
Old Sep 4, 2008 | 10:37 PM
Jfsram's Avatar
Jfsram
It's long gone now but I used to have an 88 with the same problem.
After fixing all the recommended pieces. I just gave up and drove it.
Flicking the key from off to run before it actually shut off. Would cure the high idle for a few days.
After finding the off, on key trick I refused to believe it was anything mechanical like a intake leak.
Nick Oliver
Oct 17, 2018 04:22 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zanemoseley
Sep 6, 2015 12:58 PM
