Help ... Engine idles at 1400 RPM when hot.. 4bbl holly 1985
My 1985 Mustang GT idles at 1400 when the engine is warm. I am able to give a quick jab on the accelerator pedal and the idle speed returns to normal. About 600 RPM. I have the same "High Idle" problem every time I stop at a traffic light.
I am always able to give the accelerator pedal a quick jab and the idle returns to normal idle speed about 600 RPM.
Note the choke does open up fully when the engine is at normal temperature.
Thanks
[align=left] [/align]
Thanks
RE: Help ... Engine idles at 1400 RPM when hot.. 4bbl holly 1985
I believe if it is all factory carb still..thaT THERE is a dash pot / idle bump up infront of the throttle linkage and check the linkage to make sure the idle bump up on the choke circuit isn't hanging open...if you had a pic of your carb set up I could tell better what you are equipped with..it's been a while since I removed my stock stuff
musnicki
09-23-2015 07:11 AM
09-02-2015 08:40 PM
