Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Carb Distributor ??
Old Aug 30, 2008 | 09:40 PM
94gtcobra's Avatar
94gtcobra
Default Carb Distributor ??
I got a 67 Mustang with a new Roller Block installed, I need to know what distributor is needed. I hear that 85 distributors work, if i can't find that specific distributor what else can i use, i dont want to buy a new one.
Old Aug 30, 2008 | 09:58 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
buy a reman one at local parts store
Old Sep 1, 2008 | 04:10 AM
Gary H's Avatar
Gary H
You really just need to change to a steel gear.
Old Sep 1, 2008 | 02:00 PM
mstngsule68's Avatar
mstngsule68
you need a distributor that is non pcm controlled like a points or hei something like that... personally id go on ebay and for 55$ buy the hei. i havent had a problem with it yet.
mstngsule68
oh and yea steel gear, which an hei has.
Old Sep 23, 2008 | 10:24 PM
Mustangdemon67's Avatar
Mustangdemon67
you can use the old dizzy from the 67 289. all you need to do is get the hardened steel gear for the roller cam.
Old Sep 23, 2008 | 10:31 PM
P Zero's Avatar
P Zero
You can use just about any 302 disty that has the duraspark type ignition. Any '79/'82-'85 dist will work (there was no 302 in '80 or '81).
So heres all the ones thatll work, Ford Fairmont/mercury zephyr, Thunderbird, Crown vic/grand marquis/LTD, F/E150, hell any ford vehicle made between '79-'85 that had the duraspark with a 302.
-P.
Old Sep 24, 2008 | 01:09 AM
mstngsule68
ive never had a problem with this, double check its a steel gear on it.
http://cgi.ebay.com/ebaymotors/FORD-...mZ270277634384
Old Sep 26, 2008 | 09:18 PM
67mustang302's Avatar
67mustang302
Or you could spend the money on a more modern distributor that doesn't have nearly as many moving parts.
http://www.cranecams.com/index.php?s...&lvl=4&prt=127
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
dalehunter
Sep 25, 2015 10:51 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
