Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
carb problems
Old Sep 24, 2008 | 04:57 PM
jjw88mustang's Avatar
jjw88mustang
Default carb problems
This is for a friend of mine that is having some troubles if you guys have any ideas at all that would be great sorry for the length.
well i just bought a 750 dp quickfuel ss after numerous moving of vaccum lines and helicoiling two studs in the intake mani i got it on and running, car ran real good, then the fuel line started leaking, tried fixing it today and things got bad.
yesterday the car started right up and ran real good, today it seem to run really rough, seemed like a miss, while driviing i couldnt get the car over 3 grand and the whole time it sputtered and acted like it was trying to die jut around the block.
i dont hear it sucking air, and the idle doesnt hang so i dont thing its vaccum...
so my two thoughts are a fouled plug or the carb is loading up, niether of which i have dealt with so how can i spot them?
also i have a holley red electric pump and i had it pumping fuel for 10-15 seconds while i was checking for leaks, and i had started it after a hour or so sitting, it ran better but still real rough around 2500 rpms
and if anybody has any other possibibilties let me know.
Old Oct 3, 2008 | 05:32 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Have you checked you timing at all?
Old Oct 14, 2008 | 12:13 AM
mstngsule68's Avatar
mstngsule68
check your timing, check your fuel press, and check your plugs, i had a set foul out on me within a day once.
uberstang1
Sep 20, 2015 06:42 PM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
tramphardrocker
Sep 13, 2015 08:56 PM
